circle - line fillet
kirk_2
Member Posts: 34 ✭
I have noticed that neither SW or OS will do a fillet between an arc and an intersecting line, something that Draftsight does and that I use a lot. The alternative is the perimeter or 3-point circle, which I personally find more awkward. Any thoughts?
LearnOnshape facebook group
https://cad.onshape.com/documents/d64ef7ff44c94b4ea810c289/w/64b1bc5c0d274d1d89c58e7d/e/52af5c83def74824b5ccdc3a
TVP, Onshape R&D
TVP, Onshape R&D
Testing shows that selecting a spline and a line on my mac works fine but trying to do the same thing on my iOS device does not work. Even when the radii should work with the geometry. It works when selecting the intersection point but that is no good if there is no intersecting point. I have submitted the bug and shared the model with support
TVP, Onshape R&D
