Changing existing Radius Form ?
oliver_berger
Member Posts: 5 ✭
Hello all
i am really bad with CAD, but i managed to draw a grip for a wheel a while ago. After 3D Printing and testing, i have to change the outside radius, to make it more round like the inside of the grip.
Sadly i can't figure it out how i can change it. Not sure if i have somehow first to add more material to it.
Or do i have to start from scratch ?
Not sure if i have to link my drawings or if you can find it.
Maybe someone can get me some directions.
Thanks
Thanks
lana
Onshape Employees Posts: 746
Can you provide a link to your document? This will make it easier for others to help you. Information on sharing a document can be found here : https://cad.onshape.com/help/Content/sharedocuments.htm .
Sometimes it is easier to just do something in the product than explain it in words (and this one was pretty complicated). Since Lana's copy of the document is public, you can press "make a copy" at the top to copy it back to yourself. Once you have it copied back to yourself, You can use the rollback bar to step through each of the operations Lana did and see how the new part developed:
search for "rollback" on these help pages
https://cad.onshape.com/help/Content/feature_list.htm
https://cad.onshape.com/help/Content/ui-basics.htm
It also may be helpful to hide your original part by pressing the eye next to "Part 1" in the parts list and to make the new part opaque using the appearance editor:
https://cad.onshape.com/help/Content/appearance_editor.htm
In general, these direct modeling operations on an imported model have a steeper learning curve than modeling from scratch and @lana is a CAD expert so don't expect to be able to do this on day 1. Hopefully you can learn something new by going through her steps, or by watching some of our videos!
https://www.onshape.com/videos/topic/tutorials
