Get me started on this Sink Design
 Krys
                    Member Posts: 9 ✭
Krys
                    Member Posts: 9 ✭
                    I am trying to design a sink for my bathroom remodel which I will cut on my CNC machine. Problem is I have no idea how to do this design the sink in this picture. I can easily make a rectangle sink with a rectangle hole, but the curve from the surface down to the drain is the problem. I am not even sure what to google.
thanks in advance
thanks in advance
The sides are vertical and I imagine you'd want them on a bit of an angle, but this should be a good starting point...
Linked[in]
@Kyrs it would be great to see some pic's of the whole process from Onshape to bathroom.
@BruceBartlett if I can get this thing modeled I would be happy to post a video of the actual product.
I've modeled up my approach too.
https://cad.onshape.com/documents/49e93d7ca8ca45ebb1bb5cf1/w/321e231b774541d18a2d7fba/e/72b1649632f74afea1be2710
What you need to do next is make this out of concrete... I have built a few of these integral sinks, using concrete.
1) what material are you planning on machining this from?
2) what type of mill do you have? How many axis?
3) what CAM software are you going to program this in?
4) are you planning on profiling the sink cavity? Are you going to leave the bottom of the sink square or will you flip it over and then work the bottom?
5) what type of finish are you looking for?
Ill try and help you out with solid model
1) Planning to make this out of 4-6 layers of solid wood butcher block style, then coating it with some clear coat to seal it. This is just a powder bath in my house that doesn't get much traffic.
2) I have a 3 axis 4' x 8' CNC router. Its a kit from CNC Router Parts
3) I will try to CAM this with Aspire/VCarve 8 which I should be able to do with no problems, I also have Autodesk Inventor which has HSMXpress CAM built in as a backup
4) Not sure what your asking. Probably leave the bottom alone, if I did end up doing both sides I will just have to set up a jig and flip each layer, but design wise I think I will like the look better if it just looks like a solid block of wood with a sink cut into it.
5) I plan to rough finish with a flat endmill, then do a nice finish pass with either a .25" ball nose or .5" ball nose depending on what I think will look best once the design is done. Glue all the layers together, sand, then stain the piece and add clear coat to seal it.
Thanks for pitching in, this is all just a side hobby/small money maker for me so it might take me a few weeks or so to complete (much faster with all you CAD experts pitching in).
@Joe Dunne That is the plan for my outdoor barbeque/kitchen area.
