How can I delete part of a split surface (not part)
SledDriver
                    Member Posts: 117 ✭✭✭
                    I have a surface which I have split with another entity. How can I delete either part of the split. Delete face deletes the entire original surface. I only want to delete the part inside the ellipse. This is easy with a part, but not so with a surface it would seem.
SledDriver
                    Delete part does not work in this scenario, nor does simply hiding the surface, which hides the entire entity.
The answer was to "Delete Face" with "Leave Open" set as an option.
https://cad.onshape.com/documents/d1df160ee7b2bfee22ebc304/w/810da20374b5f2554675efd0/e/6159e393de3d2768b57d6965
Split the surfaces...
