FEA simulation? for " O-RINGS" "not what I want"
Creating an O-Ring is a very simple task as well Creating O-Ring grooves I used an O-Ring Calculator to verify tolerances and fluid type this calculator is really easy to use http://www.applerubber.com/oring-gland-calculator
anyway I just don't believe an o-ring with a material spec of Silicon Rubber against 6061 aluminum can't be spec'd to
compress instead of just passing right into the 6061. if the parameters of the material could be changed to dynamic within its self and against other objects that would be amazing..
During the "Squish" of the O-Ring the sides expand equally in the groove based on the total amount of compression applied.
The O-Ring i'm using is a 1 x 3 x 5 (t, id, od) or (dimensions) (thickness) (inside diameter) (outside diameter) = .039 x .118 x .195, total Squish = .012 which translates to .003 on each side of the O-Ring in the groove, forces from the id and the outside diameter are combined which is .006 each for a total of .012 / 4 = 3 the groove is .124 and the bore is .186 and groove width is .054 so imagine an ellipse if you will once compressed I realize anFEA Simulator would show potential flaws, I don't have that problem... I want those O-Ring to Squeeze into the bore and expand when released when animated.. I know I can make them elliptical.. That's not what I want to do, it's great for a picture just not great for a demonstration video..
Thanks in advance
Stephen Normyle (COWBOY)
Thanks in advance
While you could use FEA for a very accurate shape. That seems like overkill. It would require a high end tool. Something like multi physics product will do this.
You could also model the xsection of the oring with a ellipse in Onshape. Then using the H and W values of the ellipse you can then change the values from squished to a circle... a before and after.
While this isn't exactly what you asked for - many people read these threads and some may be interested to learn that there is a public custom feature that will create 'squashed' O rings - preventing them from showing up as 'interfering' parts.
https://cad.onshape.com/documents/57896d4ee4b0f979c401da20/w/25dc73fef97a652c054ee6e1/e/8817b266f99342c53037c3a0
Have fun
