Can Onshape do Sheet Metal lofts?
Can Onshape do Sheet Metal lofts? If so is there a tutorial?
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
No, Onshape doesn't have a feature to do square to round sheet metal lofts yet.
However, with a bit of effort, you can make it happen. See doc here. I'd be interested to see if this suits what you're after to help @lana add this in the future.
Maybe someone could even write a feature script to create the square to round transition with flat faces to make it easier for the short term.
6 -
joseph_terpend Member Posts: 17 ✭✭
Thanks, I will wait for Onshape to get sheet metal lofts sorted.0
The trick is to get the faces on the part flat before you convert to sheet metal. In this example, I used the loft feature but then had to patch the flat chamfered corners in.
We have not this yet, but it is on our radar.
You can vote here: https://forum.onshape.com/discussion/9297/loft-sheet-metal
