Can Onshape do Sheet Metal lofts?
joseph_terpendjoseph_terpend Member Posts: 17 ✭✭
Can Onshape do Sheet Metal lofts? If so is there a tutorial?
  • joseph_terpendjoseph_terpend Member Posts: 17 ✭✭
    Thanks, I will wait for Onshape to get sheet metal lofts sorted.
    You can't do sheet metal loft as a feature in Onshape, but you should be able to create the shape as a solid and use the sheet metal convert.
    The trick is to get the faces on the part flat before you convert to sheet metal. In this example, I used the loft feature but then had to patch the flat chamfered corners in.
    So Onshape cannot do square to round sheetmetal lofts yet?
  • PMGPMG Member Posts: 2 PRO
    Has this issue been resolved yet?
    @PMG
    We have not this yet, but it is on our radar.
    You can vote here: https://forum.onshape.com/discussion/9297/loft-sheet-metal
