Featurescript fails when using EvBoundingBox?
Hello all,
I'm currently trying to write a script which evaluates the bounding boxes of a given set of parts, and then prints the vertices to the featurescript terminal. However, when I attempt to do this, it breaks and throws a Precondition of evBox3d failed (arg.topology is Query) error. I have added my code below. I'm sure it's a simple syntax thing, but I'm having a hard time finding relevant information online. Any help is greatly appreciated!
<br>FeatureScript 626;<br>import(path : "onshape/std/geometry.fs", version : "626.0");<br><br>annotation { "Feature Type Name" : "Name Parts" }<br>export const NameParts = defineFeature(function(context is Context, id is Id, definition is map)<br> precondition<br> {<br> annotation { "Name" : "Parts", "Filter" : EntityType.BODY, "MaxNumberOfPicks" : 100000 }<br> definition.bodies is Query;<br><br> // Define the parameters of the feature type<br> }<br> { <br> for (var parts in definition.bodies) {<br> // define bounding box<br> const boundingBox is Box3d = evBox3d(context, {<br> "topology" : parts ,<br> });<br> println(boundingBox.minCorner);<br> println(boundingBox.mazCorner);<br> // assign names<br> // <br> // <br> }<br> <br> println(" this is the list of parts" );<br> <br> });<br><br><br>
lana Onshape Employees Posts: 737
I think you intend to dofor (var parts in evaluateQuery(context, definition.bodies))
The way it is written now, your loop iterates through map entries of definition.bodies5
