Hole tool - depth to a selected surface or next surface
brian_brady
Member, Developers Posts: 505 EDU
Am I missing something, or is there no way to use the hole tool to make a hole depth end at a specific surface or go to the next surface? I can only find to a specified depth (value) or thru (completely). I would deduct points if my students used an arbitrary depth when the design actually needed a hole to only go up to a specific surface. We can do this in CREO but I cannot find it in OS.
Brian
Brian
1
viru
Member, Developers Posts: 619 ✭✭✭✭
@brian_brady, Currently this facility is not available in Onshape. You can raise improvement request for this. In near future we hope that this facility will be provided by Onshape like Solidworks and Creo.
5
As a work around you can create extrude and remove the material.You have the "Up to face" option in Extrude.
Honestly (aimed at OS not you) the improvement request system leaves much to be desired, so I generally don't even bother.
