Correct Tools Query Call for opBoolean Union of Shelled and Intersected parts
jasen_raboin
Member Posts: 4 ✭
Very frustrated. I'm at the very end of my Feature script that creates 3D lattice infill for parts and I can't get the last operation to work
Below is the tail end of my script, the very last operation "//Union of Shell and Intersect" always throws an error
// do this only if the 'preview' option is un-checked
"@opBoolean: BOOLEAN_BAD_INPUT". I've tried everything from calling the shell and intersects, setting attributes and calling the attributes, creating variables to assign the qUnion to and using the variable. There is something about the order of operations that i don't understand where I can't query the right thing. By the way, you can manually create the Union outside of FS, so I know it can be done! Any help would be appreciated. |
if (!definition.BeamPreview)
// Union of all Beams
opBoolean(context, id + "Union1", {
"tools" : qAttributeQuery("Beam"),
"operationType" : BooleanOperationType.UNION
// Make a copy of the part to fill
transform(context, id + "Copy1", {
"entities" : definition.PartToInfill,
"transformType" : TransformType.COPY
//Intersect Copy with Beams
opBoolean(context, id + "Intersect1", {
"tools" : qUnion([qCreatedBy(id + "Copy1", EntityType.BODY), qAttributeQuery("Beam")]),
"operationType" : BooleanOperationType.INTERSECTION
//Shell Original Part
opShell(context, id + "Shell1", {
"thickness" : -definition.WallThickness
opBoolean(context, id + "Union2", {
"tools" : qUnion([definition.PartToInfill, qCreatedBy(id + "Copy1", EntityType.BODY)]),
// endif BeamPreview
jasen_raboin
Member Posts: 4 ✭
Ran debug on all queries for the Union1, Copy1, Intersect1, Shell1, definition.PartToInfill. All resolved to nothing except Intersect1 and definition.PartToInfill which resolved to 1 body. So I used those two entities in the query call and it worked! I should use debug more often! So bottom line is that an opBoolean Intersection takes over the attributes of the tools used which then go to nothing. However a opShell does not affect the attributes of the tool entity and the shell query is nothing. Thanks.1
A piece of general advice is to use
to see what a query resolves to.
var trackIntersectionQ = startTracking(context, qCreatedBy(id + "Copy1", EntityType.BODY));
in the last boolean use qUnion([definition.PartToInfill, trackIntersectionQ]);
opPattern(context, id + "Copy1", { "entities" : definition.PartToInfill, "transforms" : [identityTransform()], "instanceNames" : ["1"] });Onshape is a very powerful and open system - you can do things (like build a lattice) that are impossible in other systems.
That said, a lattice will be VERY VERY VERY VERY SLOW!
Think about it, a casting may have 100 faces - a lattice will have 10,000 or 100,000 faces. This is more than any part you would ever design.
This large number of faces will manifest in very slow boolean times (almost definitely longer than the 10 minute time out for custom features) and even if it succeeds, the complexity of the body will cause very long open times and very long operation times.
Bottom line, please do not create lattices of any complexity.
This is not a limitation of Onshape, this is a limitation of Brep modeling.
I hope this helps
