DXF export fails to export feature pattern elements
michael3424
Member Posts: 751 ✭✭✭✭
I'm trying to export the face of this part as a DXF file but only the upper left cutout is being exported. The 8 cutouts that are not exporterd are part of a feature pattern. This is a public version of the document:
https://cad.onshape.com/documents/b00cfd4b5ca46554a55c9226/w/f5eedbf468f3aab23ece40b6/e/cf0941c4b9dd75f0358ab6c3
Can someone explain what I'm doing wrong?
NeilCooke
Moderator, Onshape Employees Posts: 5,931
You are probably selecting the sketch. Hide it first or use select other.Senior Director, Technical Services, EMEA5
