surface not splitting object when should
Luke_ChaseLuke_Chase Member Posts: 8 EDU
I have a surface that can split a surface once, but when I try to split the same object (at a certain angle) it says that the object can not be fully split by the surface. Here's the project: https://cad.onshape.com/documents/c5d62b49a40668470e9d717d/w/0a8437eee5d862df1a11df95/e/79c2b44b73fe0f5956506a30
