New to OnShape and CAD in general
Hello Everyone
I am trying to create a top piece for a race drone that will protect the camera and house a receiver and video transmitter.   I have the basic shape, but I am stuck on a few things.
Firstly here is the link to the project  https://cad.onshape.com/documents/94e3510999ab8a61cfed5c1b/w/69df2d67275b25f368368be9/e/f6e1e832ac5d8958ccf0c0ed
Ok so issues I'm unable to resolve:
1.  There is a sketch entitled 'bottom plug'.  How do I make this 1.5mm thick and place it on the bottom of the directly below where the sketch is under the rectangular hole?
2.  There is a sketch entitled 'antenna hole (r)'.  How do I make a post with a hole 3mm in diameter with a 1mm wall 45 degrees to the face of the wall, and how would I repeat that for the other side?
I plan on printing this with TPU. if that makes a difference.  Any help/advice would be greatly appreciated
Thank you
Chris
  • christopher_oehlerschristopher_oehlers Member Posts: 2
    Sir
    You saved the day.  Thank you very much!!!
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,048 PRO
