Dimension a drawing on anrdoid tablet
joseph_terpendjoseph_terpend Member Posts: 17 ✭✭
Is there a way to dimension drawings on Android tablet. When measuring on site I create simple solid models but it would be good to  be able to add dimensions on the sheet drawing to check that I have things in the correct place.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    Drawings are not yet implemented in the mobile app.
    You may view drawings, but not modify.
    I'm not sure if they plan in adding this or not. I would submit an improvement request if I were you.
