Overloading function defenitions
Is there an opportunity to overload user defined functions for several types of arguments? For example for ValueWithUnits and Vector types?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    You can, but it's also just as easy to specify no type in the function declaration and then test the type within the function.
    @NeilCooke I'd like to test perfomance for if operator vs function overloading, so i should just add another function with the same name for another type of argument?
    edited August 2017
    Yes that will work
