Problem with the exercice "Basic features 1" of "Introduction to CAD"
Hello everyone,
I'm learning how to use onshape with "Onshape basis, introduction to CAD". I
And I'm getting mad with the basic features 1! My volume is 1.516 inch3 and it isn't the correct answer… and I don't know why. I spent hours without any change.
You can see my work here:
https://cad.onshape.com/documents/5720b43fb61be851e8e66fd9/w/07b8823a7e8c2ea1c87515ab/e/def78185f703154e799d8f84
What's wrong with it?
Can someone help me?
Thanks,
Cédric
Thanks,
Cédric
OwS.
Cheers, Owen S.
Do you have a link to the question?
In general, if you are able to post a public link to your doc, there may be people who can help you debug.
Here is a place to start:-
You see I've:-
(1) Taken your part and derived in the answer's part as an overlay.
(2) Copied both parts via a transform.
(3) Boolean subtracted the results to show the exact differences.
https://cad.onshape.com/documents/97e91d0a58ba5a94db44bf34/w/c708fda8e13ecc4aee694a27/e/1595717b3ccac7b508d2e099
Sorry, I've not read through the exercise to see what the problem is.
Hope that helps, Owen S.
When I select the link that @owen_sparks has just posted, rather than opening a document that relates to this topic my browser takes me to my own recently opened documents with a message at the top saying "Failed to load document for workspace. Resource does not exist, or you do not have permission to access it." This is the second time this has happened in 2 different threads over the past few days.
I am using an up-to date Chrome 64bit browser on 64bit Windows 10 and I have flushed the cache to see if this clears the problem and it doesn't!
Anyone else?
The document exists but I'd failed to make it public. So when I clicked the link to test it it worked fine, but when you clicked it it wasn't available so is defaulted you back to your recent docs.
Sorry for wasting your time, and please retry if you're still interested.
