Replicate assembly components with rotation
adamohern
Member, OS Professional Posts: 216 PRO
I have a bearing secured with two fasteners, and I need to add 32 instances of this subassembly to a mounting plate. Replicate works for a single mate, but not for a component requiring two mates like this one.
What would be the best way to approach this without manually mating each bearing?
If that doesn't work, I would create a circular feature pattern of mate connectors at the part studio level, then go into snap mode.
In this case, I ended up brute-forcing it by adding the first eight bearings manually, then doing a circular pattern to match the hole pattern. Still, it would be nice to know of a better way.
If you share the document with support I can show an example.
UX/PD/Community Support
If I could I would simply create mate connectors in the sheet metal plate at the original hole pattern instance, and then include it in the patterns that create the holes. I imagine mate connectors could be included in any kind of pattern, including body, face, and feature patterns. This way I could include mate connectors with the proper orientation for each hole.
Notice in your image that the mate connectors are not oriented correctly.
