A "New" extrusion on part won't update in my assembly??
Hi, I'm confused to why A "New" extrusion on my part won't update in my assembly?? I've been trying for
if I click the "add" button then I'll see it in my assembly. I want it to be a "new" extrusion because it changes the colour of the extrusion. this is what I want.
Any help would be appreceated
The best way to get help on the forum is to post a link your document (as a free user, your documents are public, but we don't know which one you are talking about). At that point, 5 people will fall over themselves to fix it for you (or tell you whats going on).
Looking forward to helping you
ok great, I'm relitivly new to Onshape so I'll try to figure out how to link the drawing. I've used Solidworks before for many years.
sorry I was speed typing when I wrote the comment.
In my drawing I have a few parts and an assembly. I edited one of those parts. I added an extrusion. the extrusion section seems to have different options. New, Add, Remove and Intersect. if I choose "add", it adds it to the part, so when I go to my assembly, I can see the extrusion I added. and its the same colour as the part i extruded it from.
The problem I am having is when I choose the "New" option in the extrude section. if I do it this way I cannot see the extrusion once I go back to the assembly. I can only see it when I go back to the part.
This should be the link to my drawing.
https://cad.onshape.com/documents/ff8039784dc3dce584ea3b8b/w/087a6848f9fc44fde98ec894/e/d4c560fefce163c3eaf48e58
- Part I am having an issue with is "Property limits" theres a grey "walk way" around the property.
- I would like it to show up in "Assembly 1"
Hope this is a little more clear.
Thanks
That said, let me see if i can help you.
While it is not definitively apparent from your document what your problem is, i think i can hazard a guess.
In Onshape, a Part Studio is for making parts. Most of the time, there is only one part per Part Studio. The only reason to create a second (or third) part in a Part Studio, is if those two parts are geometrically related (this is akin to an icontext feature in a SolidWorks assembly). There is nothing 'wrong' with building more than 1 part in a Part Studio if they are not related, its just not as efficient (performance)as building them in separate Part Studios.
Next - if i insert the contents of Part Studio into an assembly, i am not inserting a 'sub assembly', i am literally inserting whatever was in the Part Studio at that time. It is a common misconception that if i later add another part to the Part Studio that it will appear in the assembly (it will not). If you create a new part in an existing Part Studio, it is no different than creating it in a new one - that part must be added to whichever assembly it goes in. Does that answer your question?
Also - i note that you have a lot of planar mates. Onshape mating is VERY different to SolidWorks mating.
check out the number of mates in this assembly.
https://cad.onshape.com/documents/06ba4d5e7818cfd088e3fdcf/w/612e42a22aaf5e2b8906c30a/e/874780541e8b5bf95a3cfa26
One per sub assembly and 8 at the top level - and that's for full motion!
I hope this helps.
As for my drawing, I drew my "walk way" in the assembly 1 using edit in context. this way I had all the references I needed. If I had to open a new Part Studio and draw my walk way I would have had no references to draw it.
is there a way to save the walk way I drew to a new part studio so that I can insert it into my assembly 1?
I'll try to stop here and figure out the rest, I know you guys are super busy!
How come when I try to insert a new part I cannot see my walk way?
Please ask any question and i will look again in the morning.
