How to find extent planes for a solid in a specific direction
Member Posts: 89 ✭✭
edited August 2017 in FeatureScript
I have created a feature script feature. The user can select
  • S is Solid
  • P is Plane
I would like to generate two planes that bound in the direction of normal to P
Before:
After:
Any ideas how to do this?
  • Member Posts: 1,221 ✭✭✭✭✭
    edited August 2017
    evBox3d of solid S with tight option will give you 2 vectors and the direction of plane P will give you the normal, so you can construct 2 planes.
    in the arbitary case you may requare to construct local CS to pass into evBox3d, as X axis could be used normal of plane P, Z vector can be obtained by perpendicularVector(xVector)
  • Member Posts: 89 ✭✭
    Here is a solution
    FeatureScript 660;
    import(path : "onshape/std/geometry.fs", version : "660.0");
    annotation { "Feature Type Name" : "Auto Rib" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Part", "Filter" : BodyType.SOLID, "MaxNumberOfPicks" : 1 }
            definition.Part is Query;
            annotation { "Name" : "Rib Direction", "Filter" : GeometryType.PLANE, "MaxNumberOfPicks" : 1 }
            definition.Plane is Query;
            annotation { "Name" : "Number of Ribs" }
            isInteger(definition.myCount, POSITIVE_COUNT_BOUNDS);
            annotation { "Name" : "Rib Thickness" }
            isLength(definition.myLength, LENGTH_BOUNDS);
            const p is Plane = evPlane(context, {
                        "face" : definition.Plane
            var b is Box3d = evBox3d(context, {
                        "topology" : definition.Part,
                        "cSys" : coordSystem(p)
            const t is Transform = toWorld(coordSystem(p));
            b = box3d(t * b.minCorner, t*b.maxCorner);
            opPoint(context, id + "minCorner", {
                        "point" : b.minCorner
            opPoint(context, id + "maxCorner", {
                        "point" : b.maxCorner
            const p0 = dummyQuery(id + "minCorner", EntityType.VERTEX);
            const p1 = dummyQuery(id + "maxCorner", EntityType.VERTEX);
            cPlane(context,
                    id + "pl0",
                    { "entities" : qUnion([definition.Plane, p0]),
                        "cplaneType" : CPlaneType.PLANE_POINT,
            cPlane(context,
                    id + "pl1",
                    { "entities" : qUnion([definition.Plane, p1]),
    The test result is
    I would prefer the the planes are vertically aligned correctly but the result is not incorrect.
    edited August 2017
    i see here some redundant code, when you obtained "p" you can make construction planes in a fewer steps like
    p = coordSystem(p);
    b = evBox3d(context, {
                        "cSys" : p
    b.minCorner = toWorld(p,b.minCorner);
    b.maxCorner = toWorld(p,b.maxCorner);
    opPlane(context, id+"minPlane",{
    "plane": plane(b.minCorner, p.zAxis),
    opPlane(context, id+"maxPlane",{
    "plane": plane(b.maxCorner, p.zAxis),
    A better solution is to project the box3d corners onto the original plane vector. Then the result planes are just offset from the original
    FeatureScript 660;
        precondition
            b = box3d(t * b.minCorner, t * b.maxCorner);
            const line is Line = line(p.origin, p.normal);
            const p0 is Vector = project(line, b.minCorner);
            const p1 is Vector = project(line, b.maxCorner);
            opPoint(context, id + "p0", {
                        "point" : p0
            opPoint(context, id + "p1", {
                        "point" : p1
            const p0Id = dummyQuery(id + "p0", EntityType.VERTEX);
            const p1Id = dummyQuery(id + "p1", EntityType.VERTEX);
            cPlane(context,
                    id + "pl0",
                    { "entities" : qUnion([definition.Plane, p0Id]),
            cPlane(context,
                    id + "pl1",
                    { "entities" : qUnion([definition.Plane, p1Id]),
    And dropping down to using opPlane instead of cPlane makes the code shorter and avoid inserting dummy points into the model
    FeatureScript 660;
        precondition
            const pl0 is Plane = plane(p0, p.normal);
            const pl1 is Plane = plane(p1, p.normal);
            opPlane(context, id + "pl0", {
                        "plane" : pl0,
            opPlane(context, id + "pl1", {
                        "plane" : pl1,
