How to find extent planes for a solid in a specific direction
I have created a feature script feature. The user can select
Before:
After:
Any ideas how to do this?
- S is Solid
- P is Plane
Before:
After:
tight
option will give you 2 vectors and the direction of plane P will give you the normal, so you can construct 2 planes.in the arbitary case you may requare to construct local CS to pass into evBox3d, as X axis could be used normal of plane P, Z vector can be obtained by perpendicularVector(xVector)
The test result is
I would prefer the the planes are vertically aligned correctly but the result is not incorrect.
p = coordSystem(p);
b = evBox3d(context, {
b.minCorner = toWorld(p,b.minCorner);
b.maxCorner = toWorld(p,b.maxCorner);
opPlane(context, id+"minPlane",{
"plane": plane(b.minCorner, p.zAxis),
opPlane(context, id+"maxPlane",{
"plane": plane(b.maxCorner, p.zAxis),
