Radius dimension goes OFF the page.
ricky_barnabyricky_barnaby Member Posts: 10 ✭✭
When the origin point for the arc is so far away that the line goes way off the page... How do i pull the origin back in creating a Zigzaged radius dimension line?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,002 PRO
    I don't think you can at this point. May want to add an improvement request.
    until then, you will need to fake it with "hand typed" dimensions to some construction lines.
  • ricky_barnabyricky_barnaby Member Posts: 10 ✭✭
    Thanks for the reply. I certainly will request this.
