reuse sketches and planes in other parts studios
daniel_weseman
Member Posts: 17 PRO
Hello
Im a OnShape newbie ,and so i have made some data management errors . I basically modeled way to many parts in one studio,so want to go back and reorganize. I want to reuse several sketches and planes I created in the new parts studio to contain only the Master sketches.
I know this must be really simple, and wanted to give support a brake,as well and try the forum. Thanks for any Advice
Dan
Dan
https://cad.onshape.com/help/#derived.htm?Highlight=derived
Thanks
Going forward, if you spread assembly across documents be aware that you need to create a version before you can use part / subassembly in another doc (higher level assembly).
projektowanieproduktow.wordpress.com
and you can always go back and edit which version you're derived from if need be.
