Joining Text
john_doubleday
Member Posts: 58 ✭✭
I have been trying to join text but unable due to the presets for 'Text'. I wish to create one part for laser cutting. How can I change the presets so that I can join the text
owen_sparks
Member, Developers Posts: 2,660 PRO
Ah, OK, I think I get it. So you want to take a bunch of overlapping shapes in one or more sketches and from that get a single outline to cut?
As ever many options. You could work in the sketch or with solids parts.
Here are 2 ways, my preference would be b:-
(a) Create another sketch on top of the first and make use of the "use" feature to project whichever lines you want, then export this sketch as dxf. You may need the "trim" tool to remove any unwanted lines. (You could work on the first sketch with the letters in, but I'd use a 2nd one on top just so you don't mangle the original text should you wish to do a version 2.
(b) Extrude the solid letters individually, move them around with the "transform" tool and when happy "boolean" (merge) them together. Then right click on the face and export the face as a dxf. This has the advantage that you can see what the finished part will look like.
Shout if you need more.
HWM-Water Ltd1
I'm sure folks will help then.
Cheers, Owen S.
