add fasten mates
how do i add fasten mates to a part every 16 inches on center for framing a wall
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
Hi Donald. Your best bet is probably to add a Mate Connector in the part studio, and then 'Linear Pattern' that connector using 'Feature Pattern' option (still in the part studio). Then when you add your beam to the assembly, it will have all the required connectors.
https://cad.onshape.com/documents/7da2b702b57db09ea1cdad69/w/b0603891b8690ef3388b182e/e/476e4517ba5195ca269b394c
Jake Rosenfeld - Modeling Team5 -
owen_sparks Member, Developers Posts: 2,660 PRO
If using the same part in each location then the assembly pattern feature is pretty neat, no need for additional mate connectors.
HWM-Water Ltd5
