Extrude separate adjacent shapes
emory_krallemory_krall Member Posts: 15 PRO
Does anyone know of a way to extrude two or more adjacent sketch outlines as separate objects? I often need to do this and wind up making several separate extrude features, but it would be much quicker and simpler if there was a featurescript or something that would do it in one operation.
    edited September 2017
    I believe the op means regions that touch each other.  In the past we've floated the concept of extruding the carcass of a draw for example.  4 individual sides but currently we'd need two extrude features else OS will merge the sides together.
    Cheers, Owen S.
    @owen_sparks - Yes - if two profiles touch or overlap today, they would be extruded as a single body. Ideas have been floated to introduce the concept of 'bodies' in sketching (allowing things like boolean operations), but the conversations have (so far) ended with "the limited benefits are outweighed by the large number of new concepts and features required". If you have any ideas on how to do this as simply as possible, we are all ears! :)
    Philip Thomas - Onshape
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,263 image
    @philip_thomas
    I think the op is just asking for a custom feature that will extrude each face of the input as a separate body.  Unfortunately I don't have time to hack this up at the moment...
    ^^^ @Jake_Rosenfeld - nice! But how does it work? :)
    It does exactly what @emory_krall has already been doing! It just calls extrude separately for each selected profile (so no guarantees on performance).
            var definitionForOp = definition;
            var count = 0;
            const relevantEntityField = definition.bodyType == ToolBodyType.SOLID ? "entities" : "surfaceEntities";
            for (var entity in evaluateQuery(context, definition[relevantEntityField]))
                definitionForOp[relevantEntityField] = entity;
                // keep original id for first entity so that manipulators work
                var idForOp = (count == 0) ? id : (id + count);
                count += 1;
                extrude(context, idForOp, definitionForOp);
    Basically make the user supply the same definition as extrude takes, then apply to each entity separately (with some id finagling).
    Some semantic sugar also:
    'definition.entities' is the same as 'definition["entities"]'
    ternary operator (var a = condition ? this : that): https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Operators/Conditional_Operator
    ^^^Nice! :)
    Works perfectly, make it native please :)
    Thanks again @Jake_Rosenfeld
    For 10 points name another CAD company that will write you two new free features with 24 hours of asking...
    Cheers,
  • emory_krallemory_krall Member Posts: 15 PRO
    Thanks @Jake_Rosenfeld!!! This is perfect. It even extrudes up to a face which is how we would generally need to use it. Fantastic!
     Hi All!
    Thanks for the kind words, glad I could help!  I've pushed a V2 with a very small fix that makes references to the created bodies more stable.
    There's also some weirdness with the "entities" box (you may notice all of your selected faces collapsing into one selection called "Missing of sketch X").  This should not be a huge problem as selections/deselections should act as usual in the graphics are.  We are investigating this as it seems like a systematic issue, hopefully it doesn't cause too much inconvenience.
    I had that same problem a while back, until I realised it was caused by the Id. :smile:
    @mbartlett21
    Yup, it's caused by the Id, but if I don't piggyback off the Id in that way, I'd have to do extra work to have the manipulators (or just not have them at all).
  • paul_bunnellpaul_bunnell Member Posts: 26 EDU
     Thank you @Jake_Rosenfeld! I'm using OnShape to make a stained glass window pattern (of all things) but as you might imagine, your script just saved me a ton of time!
    Glad to help @paul_bunnell !
  • robert_stilesrobert_stiles Member Posts: 186 PRO
    exactly what I was looking for today… thanks @Jake_Rosenfeld
