Placing a skRectangle centered on a queried vertex
 Dylan_Stewart
                    Member, Developers Posts: 107 PRO
Dylan_Stewart
                    Hello all! I am trying to write a feature that will place a sketched rectangle the is centered on a queried vertex. I am looking at @NeilCooke 's "Mounting Boss" feature for guidance and basing my code on what he has. I'm pretty close but I am not getting the desired results.
                FeatureScript 675;
import(path : "onshape/std/geometry.fs", version : "675.0");
export enum postSize
    annotation { "Name" : "Small" }
    SMALL,
    annotation { "Name" : "Large" }
    LARGE
export function postSizeID(value is postSize)
    return{
        "SMALL" : 4 * inch,
        "LARGE" : 6 * inch
    }[value as string];
annotation { "Feature Type Name" : "Adjustable Louvre" }
export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
    precondition
        annotation { "Name" : "My Query", "Filter" : EntityType.VERTEX, "MaxNumberOfPicks" : 4 }
        definition.postLoc is Query;
        annotation { "Name" : "Face Plane", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 }
        definition.face is Query;
        annotation { "Name" : "Post Size" }
        definition.postSize is postSize;
        annotation { "Name" : "Louvre Height" }
        isLength(definition.louvreHeight, LENGTH_BOUNDS);
        var postSize = postSizeID(definition.postSize);
        var height = definition.louvreHeight;
        const postLocation = evaluateQuery(context, definition.postLoc);
        var sketchPlane is Plane = evOwnerSketchPlane(context, {
                "entity" : postLocation[0]
        var topPlane = evPlane(context, { "face" : definition.face});
        definition.elemAdd = true;
        definition.elemId = 1;
        var nameId = 1;
        var startPoint = vector(postLocation-postSize/2);
        var endPoint = vector(postLocation+postSize/2);
        definition.sketch = newSketchOnPlane(context, id + "sketch1", {
                "sketchPlane" : topPlane
        for (var location in postLocation)
            var point is Vector = worldToPlane(topPlane, evVertexPoint(context, {
                    "vertex" : location
            // skRectangle(definition.sketch, "rectangle1" ~ nameId, {
            //         "center" : vector(point[0], point[1]),
            //         "firstCorner" : vector(point[0], point[1]),
            //         "secondCorner" : vector(postSize, postSize)
            skRectangle(definition.sketch, "rectangle2" ~ nameId, {
                    "firstCorner" : startPoint,
                    "secondCorner" : endPoint
        nameId += 1;
        buildPost(context, id, definition);
    function buildPost(context is Context, id is Id, definition is map)
            skSolve(definition.sketch);
It seems like I am just missing something small.
                Digital Engineering
Also, I realize now that my startPoint and endPoint variables are not separated by commas (fixed and still doesn't work).
Instead move defining startPoint, endPoint into the body of the loop.
const startPoint = vector(point[0] - postHalfSize, point[1] - postHalfSize);
with postHalfSize defined before of the loop.
