Editing sketch on mobile app
How do I edit a sketch on the mobile app?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015
    @joshua_dereu You can use the .. menu next to the sketch and select Edit.  Then once you are in there you can gain access to the sketch toolbar.  Don't forget the two finger tap to bring up the context menu as well.
