strange behavior of loft to build a airplane body
patrick_gubelmann
Member Posts: 3 ✭
Hello
I have a printed drawing of a airplane model. Now I'll modeling this in 3D.
I took the sliced drawings of the body and did some sketches. After I used the loft feature I got a strange body.
What is my fault and how can I fix it? Is there maybe an other possibility to modeling my airplane body?
https://cad.onshape.com/documents/cd50e7970ecf9c05cae60b82/w/5ae4b6e686a105ac70dd02ee/e/e68c7512991a67ae0d50a9fc
Thank you for your help
Patrick
Your profiles change the number of vertices as we go down the aircraft so OS does not know which vertex to match with what.
Here is one approach using a pair of "3d fit spline" curves as guides.
https://cad.onshape.com/documents/526fb2f993369d42606a01ce/w/8861fc7b3bac8ff569818eab/e/9bb68b2f7cab19cf4b42c0c4
Cheers, Owen S.
https://cad.onshape.com/documents/dd3b4d3cff189e62ad1466ac/w/00b48d091acf3b8463c53dd4/e/b7da85d0be0634e6cc41e95c
