How come I cannot choose my sketches as entities when trying to mirror?
Hi Guys
trying to mirror my sketch faces to complete the dodecahedron. I can select plane 6 as the mirror plane, but i can't select my faces to mirror.
https://cad.onshape.com/documents/d91a445de0c3ae080f0a30d3/w/9421c1ca10082898fad4ce91/e/651b333db4023c0880d09b71
What am I doing wrong?
Regards
Regards
Looks like you figured out a solution, but I wanted to show you another possible solution:
https://cad.onshape.com/documents/b7825f7115cc5593a1c4dcec/w/944aa93fd525e411d85ac3bb/e/ad69b8efb8243e60ca1593f8
If you create offset surfaces (with 0 offset) of the sketches, you can mirror those. Then you could do your transformations and then use the "Enclose" feature to create a solid:
https://cad.onshape.com/help/Content/enclose.htm
The issue here is that "Part" mirror cannot act on sketches (you could try a feature mirror of the sketches, but part mirror of surfaces will be more stable).
Here I approached your problem differently:
I sketched one pentagon, circular patterned it around, mirrored it up, rotated, then enclosed the whole thing to a solid.
https://cad.onshape.com/documents/b7825f7115cc5593a1c4dcec/w/944aa93fd525e411d85ac3bb/e/b2754a8954659f2e67fee3ad
I needed some dimensions from here, namely the "dihedral angle":
https://en.wikipedia.org/wiki/Regular_dodecahedron
