thread
oldřich_sazama
Member Posts: 2 ✭
I have a small problem, I try to create a thread and no success
https://cad.onshape.com/documents/cd182c6c970e5f7f3e1f322a/w/f0b78c05d481c7aeece4a5e6/e/10ca24f2f91fde9b443fa1cf
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi @oldřich_sazama
Couple of issues, the first being your sketch does not hit the sweep path helix.
So in this copy of your document I've added a "pierce" constraint to the sketch to make sure they connect, and also rotated the helix 90deg so we start on the end of it:-
https://cad.onshape.com/documents/4ffe7c28846ac9377418b383/w/13461373e469618f37d1b49a/e/474e97fee2d3aee67164c4a0
Worth noting that unless you really need them modeling threads is not good practice. They add a lot of overhead to the model, and if making for real then you'd probably just want the pilot drill hole in 3d with a note on the drawing to add a thread.
BTW nice project, I really miss target shooting (all but banned in the UK) so would love to be doing this kind of project.
Hope that helps,
HWM-Water Ltd5 -
owen_sparks
Hi, sounds fun. I really miss my .22lr rifles and pistols :'(
If you 3D print I would do this. Add a hole for a nut.
If you use metric nuts then there is a custom feature to make the holes. All you need is a point in a sketch.
I've added it here:- https://cad.onshape.com/documents/4ffe7c28846ac9377418b383/w/13461373e469618f37d1b49a/e/474e97fee2d3aee67164c4a0 if you wish to try it.
HWM-Water Ltd5
Hope that helps,
