Extrude at an angle
daniel_chow
Member Posts: 108 ✭✭✭
Hey guys,
Just wondering if anyone know how to extrude at a 90 degree angle from one sketch to a second sketch that are 90 degrees of each other.
Here is my public doc:
https://cad.onshape.com/documents/eb2b5e1f3972ee91b47908de/w/27e670cb0e4a4c7cafa23b2b/e/9596de02a9aa2cf47b8db808
Thanks!
Thanks!
daniel_chow
Thanks guys! Yes I tried various features in Extrude and Loft but not able to do this. I know I can set another plane and simply sketch the triangular shape I want and extrude it. But you know, bring Onshape I just thought there might be a quick workaround.
Jake, I did also try the rib tool, but I'll take your suggestion and try it again. How did you make Sketch 3 on an incline / angle like that without creating an angled plane?
Onshape rocks!!!1 -
Jake_Rosenfeld
@daniel_chow
I actually got it to work with a loft too, you just have to provide a couple guide vertices:
https://cad.onshape.com/documents/cbc0163e8e996c9d3986b089/w/ffad520e65fe3710ae29d43f/e/e6d7d60602fb2d3533ebbc9e
Jake Rosenfeld - Modeling Team6
If you're just looking to do a gusset you can do it this way. But I'm not really sure what shape you're trying to achieve.
https://cad.onshape.com/documents/2bd12d4f1859b7123e2a6718/v/73fd21de3eddfd6cb1f6c3ba/e/96c773d5da6e2010d2db205f
Loft works fine if you bring the vertical sketch off the bottom face.
https://cad.onshape.com/help/Content/rib.htm
https://cad.onshape.com/documents/cbc0163e8e996c9d3986b089/w/ffad520e65fe3710ae29d43f/e/11c486afca0b0db0e9a620fc
Onshape rocks!!!
Onshape ROCKS!
