creating a barrel cam
ihor_gernaga
Member Posts: 24 PRO
I've created barrel cams in solidworks using the wrap feature, but haven't been able to find a similar feature in onshape. Is it possible in onshape?
Thanks.
Thanks.
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
try this, you need Sketch wrapper FS with "use path" checkbox if you using a smooth law of motion
https://cad.onshape.com/documents/0bb13c1b6ed6d4a6dd75cf99/w/b4493d47a45c27ce485c84b9/e/c8050a35a7417c12b801bd40
6 -
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
Not in the app store. Open up Konstantin's doc from his link above and add the feature to your toolbar with the little plus item inside the workspace, you will also find a description and examples inside the doc. This is a great feature too btw.
here's some more help form Onshape web search https://cad.onshape.com/help/Content/customfeature.htm
6
