Cutting holes into a cylinder at 45 degree angles from Top and Right panes
Document in question: https://cad.onshape.com/documents/4c05c3523a6a7c8d5ed80c89/w/60605ddad228f2dc08782818/e/c2ad04f162bb72aa2438886f
I need to add some holes to a cylinder and I am having a hard time figuring out how to sketch those on when I cant seem to get a sketch plane created at a 45 degree angle. The holes need to be located at 45 degree angles from the rail sections, and while I think I found a very dirty work around by sketching on the front face and extruding the feature back then down, that doesn't really accomplish what I am looking for.
Ideally I would like to sketch one hole the shape I want, then use the linear and circular patters to spread those to the rest of the model so I can update the size and shape of the hole quickly.
Is there any way to do what I am looking for?
Thanks!
Thanks!
philip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
@steven_abiuso - Very Easy
All you were missing was the plane and you already had the perfect sketch entity to create it!
https://cad.onshape.com/documents/1507c9a1db09f432e7d70bbc/w/611c4c1d5416a903c72c0a01/e/51ba866ec27d34b9004bb511
Philip Thomas - Onshape6
