SHEETMETAL PART WON'T FLATTEN
michael_mcewen
OS Professional Posts: 77 PRO
I'm using the sheetmetal function for the first time. Trying to flatten a converted sheetmetal part. There are 4 bends selected. But it won't allow flattening as drawn. Cant see why not. Any suggestions?
I had originally thought to extrude a drawn profile, but in sheetmetal, I don't see any way to cut out the middle area.
Also, in sheetmetal part from converted form, I don't see any option to select bend radius. Here's a link to my simple part. Thanks.
https://cad.onshape.com/documents/8bd99e4135834978102e8db9/w/09e013edeaf76b9843ab05f6/e/b992194f1ac667f2a504940c
https://cad.onshape.com/documents/6a67ffd41f023c7e46b4cf0d/w/4b36bcc72a892801b3a6e341/e/2f6e29c908004e8b2165e70f
Thanks again,
Michael
https://cad.onshape.com/documents/155620d67eb030438c7a33aa/w/a9311f675ee9bb01fe590508/e/d2576374ead223a0f8b45236
In this case you are actually hitting a bug which will be fixed in our next release.
In this case I was able to "fix" approach in this part studio to work around that bug.
