Onshape Instructor Kit - 1.2.1 - Basic Sketching, answer off by 0.001
james_hawkins111
Member Posts: 2 ✭
I have attached the sketch and the mass properties as images. I am perplexed how the answer is so close, only off by one thousandth. I believe I have all of the tangents, but I must have missed something. Can anyone spot what I may be missing?
I have attached an image that is fully constrained. Does the fix make sense? (the value of the dimension I added is probably wrong for your purposes)
Best,
Mike
Here is a link to the document in case this helps at all:
https://cad.onshape.com/documents/7d1de9c30c97b792e9730f17/w/280c34663a4ccb798fa0a873/e/7a1af0ac882c848df42ee9a7
