Why is the revolve object in blue vs. the other parts are grey?
gianmario_scotti
Member Posts: 22 EDU
I created six shell objects with circular pattern, and then in the center I created a sphere with revolve. For some reason, the sphere is a different colour than the other parts. In fact, the sphere isn't even a part..?? Here's the link to the document:
https://cad.onshape.com/documents/45aa54e086229bce1f78c224/w/15dfd0b2f8e870cdf006f3cb/e/c4250939a996c1e63cd8c961
OptionsJake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646@gianmario_scotti,
In your revolve, use the "Add" option instead of the "New" option. and select "Merge with all" at the bottom of the dialog.
"New" will always create a new part rather than trying to merge with existing parts.
To do booleans like this, you can also use the "Boolean" feature with the "Union" option.
https://cad.onshape.com/help/Content/booleanparts.htm
Jake Rosenfeld - Modeling Team1
Looking at your sketch you do not have an enclosed profile to create a solid body. The axis line you have set as a construction line right now should be a solid line (ps. you can still use it as the revolve axis).
Twitter: @bradleysauln
