Why is the revolve object in blue vs. the other parts are grey?
Member Posts: 22 EDU
edited October 2017 in Community Support
I created six shell objects with circular pattern, and then in the center I created a sphere with revolve. For some reason, the sphere is a different colour than the other parts. In fact, the sphere isn't even a part..?? Here's the link to the document:
https://cad.onshape.com/documents/45aa54e086229bce1f78c224/w/15dfd0b2f8e870cdf006f3cb/e/c4250939a996c1e63cd8c961
  • Moderator, Onshape Employees, Developers Posts: 1,646
    @gianmario_scotti,
    In your revolve, use the "Add" option instead of the "New" option. and select "Merge with all" at the bottom of the dialog.
    "New" will always create a new part rather than trying to merge with existing parts.
    To do booleans like this, you can also use the "Boolean" feature with the "Union" option.
    https://cad.onshape.com/help/Content/booleanparts.htm
  • Moderator, Onshape Employees, Developers Posts: 373
    You ended up performing a surface revolve which left you with a surface. I am assuming this is because you don't have the proper profile set up for a revolve action.
    Looking at your sketch you do not have an enclosed profile to create a solid body. The axis line you have set as a construction line right now should be a solid line (ps. you can still use it as the revolve axis).
    Twitter: @bradleysauln
  • Member Posts: 22 EDU
    Thanks a lot, Bradley.
    I now made it into a solid, so it has become Part 7, but it's still blue.
    @gianmario_scotti,
    @gianmario_scotti,
    Thank you very much Mr. Rosenfeld - that was very instructive and solved the "problem"!
    You're very welcome!
