And the improvement to loft is terrific.
Great work!
next parting line and parting line draft....
Sr. Director of Product Definition. UX and Support
Inconsistency:
The tool icons are click first then perform that tool action. The construction tool you are expected to select the lines first then clicking on the tool to swap the lines. I'm sure this is done this way to support drag-n-select. should either add another icon and/or if the icon is clicked without any items selected then it behaves like other buttons.
Missing Tool:
Could you PLEASE add a DELETE button to the toolbar(icon)? My tablet doesn't have a keyboard so it's sort of hard to delete items. This button should also have a dual mode. actually, most tools should support this dual mode.
a) Selecting the tool first (No items selected) then for each click on an item will delete it.
b) If the user has 1 or more items selected then selecting(Clicking) on the tool just deletes all the selected item(s).
Lower clicking(On mobile app):
It only keeps a single tool at the toolbar after selecting. It looks like the tools are arranged in 3 groups + the dimension tool. a few ideas....
a) Could you keep 1 tool in the toolbar from each group after selecting it?
b) Keep the last 2-3 tools used available at the toolbar.
c) Change the single selecting icon(the one that allows you to pick any tool) into the 3 groups and keep the last item as active. A long press would cause drop-down to select another tool just from that group.
Please let me know if any of this makes sense. Thanks, Eric.
inconsistency: the construction icon is there as a toggle button. Press it before creating lines and arcs. You are right if you want to convert later you must select line first then press the icon. This is the same as in the web browser version.
Missing tool: to delete, select items first then two finger tap to bring up the context menu
lower clicking: please create an improvement request, although this is unlikely to change due to available space on iPhone.
https://cad.onshape.com/help/Content/showcurvature.htm
I am not sure what I am looking at or how to interpret the meaning of the curves. Say you have a curved surface and you want to know where the hills and valleys are or how fair or smooth it is. Say a boat/ship hull. Basically checking it to a profile tolerance. Does the link you provide https://cad.onshape.com/help/Content/showcurvature.htm help me with that?
When you said curve analysis I thought you may mean curvature analysis of edges. The curvature comb in 'show curvature' visualizes the magnitude of the curvature along an edge. Wherever the curvature comb crosses the edge is an inflection point. Discontinuities in the curvature comb indicate discontinuities of the curvature of the edge.
Unfortunately, we do not yet have surface combs similar to this. Can you make an improvement request for them?
