Extrude remove or boolean - complex profile
Hi folks. I am looking for the best way to make this object hollow - I want to make the walls about 0.75" thick. I modeled it as a solid and expected to use a boolean or extrude to hollow it out, but the exterior profile has changed and now that proves more difficult.
Any input is appreciated. Thanks!
Here is a link to the file:
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@nick_rossi
Yup! Instead of using the 'hollow' option, just select the faces that you want to be left open to the cavity.
https://cad.onshape.com/help/Content/shell.htm
Jake Rosenfeld - Modeling Team5
Alternatively, I could use an extrude to create the opening in the top.
