Add draft from 3D curve?
bruce_williams
Member, Developers Posts: 842 EDU
With SW this is easy with Extrude from 3D sketch with draft. The entire 3D top curve below can simply be extruded with draft to bottom face. Onshape does not yet support 3D sketches or extrude from 3D curves. I know parting line draft may address this when released. (ex discussion here ) - https://forum.onshape.com/discussion/comment/29874#Comment_29874
We are in the pattern & mold business and this is needed all the time.
Are there any reasonable workarounds in the meantime? OS support has suggested sweep but the profile 'twists' and the result is not what is desired (see image below). I have a sample part here - https://cad.onshape.com/documents/e794c9cce4fc26fb6ca3c849/w/8fc4464aec86e2d7ab4356c9/e/2d5a1762bcde33d83cadd8e7
www.accuratepattern.com
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,253
Does this custom feature work?
https://cad.onshape.com/documents/296e8152fa96d64827213b57/v/77f0de81053faf8ebbd98713/e/ffa7a1bd46c9e9414aeaec6f
Please keep in mind that this usage of draft has not gotten nearly as much testing as our standard draft feature.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1
Oh Yeah! I will need to work with this more but looks really good. Thank you!!
