Breaking an ICE for a duplicate part
SunkmailSunkmail Member Posts: 20 ✭✭✭
edited April 2018 in Community Support
Hi everyone,
I tried looking up how to do thins, but haven't been able to think o the right search terms ....
I made a model for some home renovations, which worked great for planning, but now I'm fine-tuning a part (countertop) I need to make based on actual measurements - my walls aren't square.
The original model countertop was made using an ICE with the new cabinets and such.
I made a duplicate of the original to make the changes to account for the non-square wall.    I was able to remove the constraints to make the changes, but I can't see what I'm missing to remove the "Broken In-Context references" warning.
I hope that makes sense - It is more of a process question than specific to my model, therefore having a link probably won't help anyone else with similar problems.  :)
Thanks!
    Try coping the whole work space then moving the newly duplicated assembly to your older work space.  That should keep the ICE references.  Might want to change the part studio & assembly before moving them though.
  • SunkmailSunkmail Member Posts: 20 ✭✭✭
    I think I didn't explain well, sorry.
    I'm trying to remove the ICE references - Is there a way to remove all of them at once?
