Fill pattern FeatureScript
I can't find out how this fill pattern works. Can some please very simple explain how it works?? Please Help
1) Select the faces of the feature you'd like to pattern.
2) Select the target face you'd like to fill.
3) Select an edge for the fill direction (pattern angle).
4) Choose your spacing/border
https://cad.onshape.com/documents/b02eed5aefc335d563b8d440/w/906f5fc8757f68a424e35f29/e/f0839677a4a7db3c242ae762
Maybe try @paul_chastell 's Fill Pattern rather than the "Circular pattern" feature that you're using?
https://cad.onshape.com/documents/580ac6963bfeb2844a03047c/w/0a8fa7b507f35cb00c9c3d72/e/b6c791f900c6253fd1127950
https://cad.onshape.com/documents/57361ad4e4b00e5012c3857c/v/eb8bfe2edd984a315033e6e2/e/14aa44d127806651b248b9c6
@mahir it appears that your "Circular pattern" feature isn't playing nicely with multiple faces here?
https://cad.onshape.com/documents/5422f3fba6539c3f00ecf19d/w/8e82a7ccc9ddfacab355652a/e/2a6792505cbaf44083c7a0e0
https://cad.onshape.com/documents/8210036e4f921a2b795c8339/w/0a1b6e46ee34f66b5f526baa/e/f36bb678d63af985f2f83eab
I finally got that the face to pattern is each face of the pattern and not the pattern itself, but when I try to select the target face I always get the face of the sketch and not the face of the extrude as in your example.
https://cad.onshape.com/documents/4d38d6ef3778b931c452644b/w/ff297763de9a5f77b3943323/e/cec3ecf962427ce001e32fa5
I need to create a circular pattern that is basically a cutout in front of each tab specified in Circular Pattern 1. If I set the merge for the extrude 8 to all then I can get a single cutout. But I can't seem to replicate the pattern since I am using Remove instead of New. Perhaps I am going about this wrong?
- Part patterns replicate solid bodies. This is useful when you have a specific geometry for the cutting tool, but not necessarily the resulting faces. After pattering you can use a Boolean to add or remove the patterned parts from your main part.
- Feature patterns replicate entire features. This is how SolidWorks users are accustomed to patterning. It's user friendly but costs more in processing power.
- Face patterns replicate individual faces. This requires more time up front since you have to select every individual face of a feature that you are trying to pattern, but it takes less time for the part to rebuild.
The fixed example below makes use of a circular face pattern. Take a look.https://cad.onshape.com/documents/3cb973a1e944a9f6c2363c64/w/221de857c5277a55fc5db58e/e/4a74a676e37e44cbf1f47f4d
I select all sides (faces) of the hexagon (as Extrude 2). Setting the target to Extrude 2 or the face of the sketch, neither works. Tried including the top of the extrude, no joy. I am obviously not understanding something but don't know what it is, and the error messages are not helpful at all. "Fill Pattern 1 did not regenerate" a why would help.
https://cad.onshape.com/documents/e15706c550e8532550901d4b/w/ad0746f0bafda4feb91256a5/e/997d5c6166e867930c226015
Seems to work with a Extrude Remove but not Add or New
https://cad.onshape.com/documents/adad529fd2168dfd3f594607/w/d71925605c33ced9bc111bcb/e/5663ab85e357ef03b34f57ff
