Problem with loft in armchair model
Marta_Milewczyk
Member Posts: 3 ✭
Hello everyone!
I am trying to make model of armchair with using loft. I looked video in onshape tutorials but my loft does not want to generate. I think this is problem with sketch, but I am not able to identify problem.
Here is my model and photo with armchair that I would like to obtain. I have two profiles and projected curve for using as a guide but my loft fails if I want to use projected curve. Do you have any idea how to make this seat? I would appreciate your help.
Here is link to my document https://cad.onshape.com/documents/140f204e6d2fe9684642f1e7/w/647aa1ceed274d1f1cff4bef/e/2fa84e8d88b81337e78f771f
Take a look at this sample model of the seat base https://cad.onshape.com/documents/947de2ceb5c7db512ce8dd54/w/20f313a4e1404a47fc55dcbe/e/636c3abe0ba57d3148f44cdc
Note that I modelled half of the shape and then mirrored it which can be a better approach for symmetric parts as you have to pick fewer entities to create the loft.
Andy
