Extrude Remove Leaves a Shell, or a Face, of the Part that was There
AnOnshapeUser
Member Posts: 6 ✭
I extrude to remove part of a piece, but Onshape fails to extrude one side of the shell of the part I was extruding. This has happened twice now. Once I got it to work by extruding to 'add' material, then I removed it all plus what I wanted. This time that trick does not work.
Any ideas for how to fix this?
thx
thx
I was not aware this is possible. I thought had to copy curves with Use command. Is this method described in help?
Onshape is like that
It is a little difficult to notice, but sketch using a model face to define sketch plane imprints this face on sketch plane.
