Improvements to Onshape - November 9th, 2017
cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
edited November 2017 in New in Onshape
Another 3 weeks, another update. Another chance to show you all the awesome things we have been working on to make your life easier.  Let's dig in.
COPY ASSEMBLIES AND DRAWINGS TO CLIPBOARD
You can now copy assemblies and drawings to the clipboard, then paste them into another Document.  All references to the assembly and drawing will also be copied.  The copied assembly or drawing is not linked to the original.
https://onshape.wistia.com/medias/0vqeqy1mjn?embedType=iframe&videoWidth=640
MATCH CURVATURE IN BRIDGING CURVE AND 3D FIT SPLINE
You now have options in both the bridging curve command and the 3D Fit Spline command to match the curvature, giving you curvature continuous transitions between your selections and the curves you are creating.
https://onshape.wistia.com/medias/mw9rrsemd3?embedType=iframe&videoWidth=640
3D FIT SPLINE IMPROVEMENTS
You can now reference a plane or planar face when specifying direction in the 3D Fit Spline command.
https://onshape.wistia.com/medias/qzmwq9if7k?embedType=iframe&videoWidth=640
INSPECTION DIMENSIONS IN ONSHAPE DRAWINGS
You can now specify a dimension as an Inspection Dimension with a new option in the Dimension Panel dialog.
https://onshape.wistia.com/medias/loes3iisdh?embedType=iframe&videoWidth=640
DRAWING DIMENSION TEXT ALIGNMENT
You will find a new Drawing Properties option to align all dimension text horizontally.
https://onshape.wistia.com/medias/x9u0j6rgdq?embedType=iframe&videoWidth=640
JOGGED ANGULAR SECTION VIEWS
You can now add jogs to angular section views.
https://onshape.wistia.com/medias/6zumt9kles?embedType=iframe&videoWidth=640
ATTACH GEOMETRIC TOLERANCE TO DIMENSION
You can now attach a Geometric Tolerance to a dimension in Onshape Drawings. Simply drag the symbol over a dimension on initial insert or after it has been placed.  You can detach at any time by dragging the symbol away from the dimension.
DRAWING PROPERTIES IN RIGHT-MOUSE CLICK MENU
You'll find a new "Drawing Properties" option when right-clicking in an Onshape Drawing.  In the past this was only available as an icon in the toolbar.
COLLAPSE PARTS LIST
You can now collapse the Parts List in your Part Studio.
IMPORT INTO MULTIPLE DOCUMENTS
You will find a new option when importing assemblies to "Split Assemblies and parts into multiple documents."  This will create Documents for each sub-assembly and part and organize them into a folder named after the top-level. To maintain ideal performance there will be a restriction to the number of parts that you can import with this option.
SELECT EDGES IN SHADED WITHOUT EDGES DISPLAY STYLE
You can now select edges when using the "Shaded without Edges" display style.
IMPROVEMENTS TO THE ONSHAPE LEARNING CENTER
We've added two new advanced courses to the Onshape Learning Center for Professional users. One for Sheet Metal and one for Managed In-Context Design. In addition, we've also made the Onshape Fundamentals learning pathway free for everyone (in the past this was limited to Onshape Professional users).
Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this latest update, please see the changelog.
    Thanks for all the improvements, specially in drawings
    Great job!!
    Un saludo,
    Great update :warning:
    My favorites this time would be copying also assemblies & drawings between documents and I've been looking for a way to have all dimension text horizontal in drawings (didn't know it wasn't possible until now).
    Thanks!
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,953 PRO
    Good updates, keep it coming!
    Copy drawings and assy's across documents is a great improvement. Alos I am looking forward to trying the new import with retained structure. Great work
    Very much like this:-
    Thanks, Owen S.
  • barry_gibsonbarry_gibson Member Posts: 31 ✭✭
    A big thank you to Mr onshape, have been banging my drum before, on this forum about training or better still trying to learn your software!! so a big thumbs up from me so off i go to the new learning center,  keep up the good work.
    Un saludo,
  • Gavin_MunroGavin_Munro Member Posts: 14 PRO
    Love the ability to copy and paste assemblies and the drawing improvements. Onshape just keeps getting better.  Thanks all
  • Andrew_Enslow_3DSAndrew_Enslow_3DS Member Posts: 40 ✭✭✭
    Special Thanks for...
    1. Copy Assemblies and Drawings - very helpful
    2. Attach Geometric Tolerances
    3. Onshape learning center expansion
    I'm not an ID guy but those curve improvements look cool. I hope I get to use them someday
  • harry_schmidharry_schmid Member Posts: 2 PRO
    Great job on the clipboard feature. Great stuff!
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,099 PRO
    My favorite:
    Learning Center upgrade looks super!  Long been hoping for that.  Thanks!!!
    www.accuratepattern.com
    @andrew_kimpton - you got a "my favorite" ;)
    Philip Thomas - Onshape
    Is this for bragging rights or is there an incentive scheme for such recognition?
    OwS
    @owen_sparks - Being able to collapse the parts list was a drum i had been beating for a while. I cornered Andrew one afternoon and got him to do it in about 10 mins. He was dubious that anyone would notice :)
    @philip_thomas   Now we need a search on the parts and surface's list, like the features list, that would surely only take 30 mins. Maybe you can corner someone to do that too.
    Search parts in assemblies too whlie you're at it!  ;)
    .. Yea yea I know, make an improvement request ...  o:)
    @brucebartlett @john_mcclary - thats on my list too.
    YES _ PLEASE SUBMIT AN ENHANCEMENT REQUEST :)
    Cast my vote
  • florianflorian Member, OS Professional Posts: 110 ✭✭✭
    Something new for drawing properties? What does it do? Or did I overlook it before?
  • cody_armstrongcody_armstrong Moderator, Onshape Employees, Developers, csevp Posts: 221
    @florian That is a new property. Aside from helping you remember if that part or assembly or file is revision managed, it does not do anything (yet).
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 255 ✭✭✭
    @cody_armstrong - You (OS) added the Inspection Dimension specification option to the Dimension Panel dialog. Very nice.
    But why not also adding the BASIC dimension specification which is very needed when using
    the GD&T “Position” Tolerance.
    This fits in the https://forum.onshape.com/discussion/7730/is-drawing-the-weak-point-of-onshape#latest topic.
    Henk de Vlaam (NL)
    But why not also adding the BASIC dimension specification which is very needed when using the GD&T “Position” Tolerance.
    @H_d_V Have you tried the "Basic" option in the Dimension Panel dialog? It's in the tolerance dropdown.  Is this what you are referring to?
    Hi @cody_armstrong,
    OK, there it is!
    Sorry for the inconvenience. I did not look at the tolerance spot, maybe because I'm still too much in the CREO mode where the basic dimension setting is outside the tolerance settings.
    Henk de Vlaam (NL)
  • OLDCADGUYOLDCADGUY Member Posts: 5
    Your search for "DRAWING LINE WEIGHT" returned 0 result(s). .. WHY?
