Improvements to Onshape - November 9th, 2017
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
Another 3 weeks, another update. Another chance to show you all the awesome things we have been working on to make your life easier. Let's dig in.
COPY ASSEMBLIES AND DRAWINGS TO CLIPBOARD
You can now copy assemblies and drawings to the clipboard, then paste them into another Document. All references to the assembly and drawing will also be copied. The copied assembly or drawing is not linked to the original.
MATCH CURVATURE IN BRIDGING CURVE AND 3D FIT SPLINE
You now have options in both the bridging curve command and the 3D Fit Spline command to match the curvature, giving you curvature continuous transitions between your selections and the curves you are creating.
3D FIT SPLINE IMPROVEMENTS
You can now reference a plane or planar face when specifying direction in the 3D Fit Spline command.
INSPECTION DIMENSIONS IN ONSHAPE DRAWINGS
You can now specify a dimension as an Inspection Dimension with a new option in the Dimension Panel dialog.
DRAWING DIMENSION TEXT ALIGNMENT
You will find a new Drawing Properties option to align all dimension text horizontally.
JOGGED ANGULAR SECTION VIEWS
You can now add jogs to angular section views.
ATTACH GEOMETRIC TOLERANCE TO DIMENSION
You can now attach a Geometric Tolerance to a dimension in Onshape Drawings. Simply drag the symbol over a dimension on initial insert or after it has been placed. You can detach at any time by dragging the symbol away from the dimension.
DRAWING PROPERTIES IN RIGHT-MOUSE CLICK MENU
You'll find a new "Drawing Properties" option when right-clicking in an Onshape Drawing. In the past this was only available as an icon in the toolbar.
COLLAPSE PARTS LIST
You can now collapse the Parts List in your Part Studio.
IMPORT INTO MULTIPLE DOCUMENTS
You will find a new option when importing assemblies to "Split Assemblies and parts into multiple documents." This will create Documents for each sub-assembly and part and organize them into a folder named after the top-level. To maintain ideal performance there will be a restriction to the number of parts that you can import with this option.
SELECT EDGES IN SHADED WITHOUT EDGES DISPLAY STYLE
You can now select edges when using the "Shaded without Edges" display style.
IMPROVEMENTS TO THE ONSHAPE LEARNING CENTER
We've added two new advanced courses to the Onshape Learning Center for Professional users. One for Sheet Metal and one for Managed In-Context Design. In addition, we've also made the Onshape Fundamentals learning pathway free for everyone (in the past this was limited to Onshape Professional users).
Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this latest update, please see the changelog.
COLLAPSE PARTS LIST
3
Great job!!
My favorites this time would be copying also assemblies & drawings between documents and I've been looking for a way to have all dimension text horizontal in drawings (didn't know it wasn't possible until now).
Thanks!
Thanks, Owen S.
1. Copy Assemblies and Drawings - very helpful
2. Attach Geometric Tolerances
3. Onshape learning center expansion
I'm not an ID guy but those curve improvements look cool. I hope I get to use them someday
OwS
brucebartlett said:
.. Yea yea I know, make an improvement request ...
YES _ PLEASE SUBMIT AN ENHANCEMENT REQUEST
But why not also adding the BASIC dimension specification which is very needed when using the GD&T “Position” Tolerance.
This fits in the https://forum.onshape.com/discussion/7730/is-drawing-the-weak-point-of-onshape#latest topic.
OK, there it is!
Sorry for the inconvenience. I did not look at the tolerance spot, maybe because I'm still too much in the CREO mode where the basic dimension setting is outside the tolerance settings.
Your search for "DRAWING LINE WEIGHT" returned 0 result(s). .. WHY?
Considering your font choice, I suppose you haven't spent too much time on forums these days? Writing in CAPITAL is considered as SHOUTING, so your message would be furious shouting while havin' a loaded shotgun ready for action..
You need to open up more that question, where did you search? help site? forums?
Do you actually wan't to know why your search did not return any results or are you perhaps more interested of changing line weight in drawings?
Onshape forums is nice and friendly environment where pretty much all questions get detailed answers.
If you wan't direct answer from Onshape, simply use feedback on ?-menu in cad site.
