What is the fastest way to place multiple identical circles in a sketch?
I was hoping to be able to select a dimensioned circle entity and paste a copy it at several locations.  The transform function seems to move entities but not copy.  Creating circle after circle after circle and then setting the dimension to all of them at once would work too but I don't see how to do that either.  The pattern function will not help since the locations do not follow any pattern.
