hide a part
billy2
Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,015 PRO
I've been working on this for some time. So there's some history.
Anyone know how?
1st try:
one would think this would do it:
Turns out this ignores the post and the 'isHidden' parameter, the others work fine.
2nd try:
I was told to read the "Feature List API" which has nothing about the hiding a part.
You can access the information with the partstudios API:
But how do you update part metadata using the partstudios API?
Seems like I'm getting the run around, can you hide a part using the API.
Please tell me which API call?
Anyone know how?
1st try:
2nd try:
So I change the name & the apperance and it updates. Try and change the isHidden property, nope doesn't work.
Can you please fix this.
Updating the current document doesn't update d/w/e. When it was working, it was nice.
Notice below the Document ID should be b7a7.....
What form does the body need to be in? Let's use the "Get Parts" API and collect body:
Now let's take that body and feed it into the "Update Part metadata" API:
Notice the server returns a status code of 200, every things ok except the body is null.
I did change the name of the part using the "Update Part metadata" API and it change it:
I also changed the property "isHidden" : true and nothing happened.
This is broken.
In the request body, it doesn't list "isHidden" as a property you can change. Searching the API there are no other calls that do it.
Please add this to the "Update MetaData" API
