Breaking up a monster document
bill_daniels
Member Posts: 277 ✭✭✭
My project document has grown far too large. Fortunately, it can logically be broken into four documents - master assembly and three sub-assemblies - but just how to do that without ruining relationships is baffling me. There are many sub-sub-assemblies some of which are used multiple times. Of course, there are many parts used in multiple assemblies. Moving an assembly to a new document drags along all the part tabs which are used in other assemblies. Drawings are yet another issue.
Any tips and tricks to offer?
That being said, taking a bunch of interrelated parts and assemblies and breaking them down is definitely a daunting process, so @philip_thomaswrote a fairly comprehensive article about it in the learning center. Check it out here: https://learn.onshape.com/learn/article/product-structure-organization-tips
Drawings are definitely an issue and we typically recommend you move parts first, which will automatically link the drawing to a version, and then you can move the drawing to the same document as the part. Let us know if that makes sense.
UX/PD/Community Support
How about making three copies of the document, then deleting tabs which aren't needed for each copy? I guess that depends on whether links and relationships are created when a document is copied.
