What do you think every new Onshape user should know?
jon_hirschtick
Onshape Employees Posts: 91
in General
As we try to develop better onboarding, training, and tips for users I want to ask you: what would be the top few things you think every new Onshape user should know?
I'll start:
General:
Onshape Documents can have many Tabs: each Tab like a Part or Assembly file, you can upload/download *anything* (PDF, SolidWorks file, etc) to/from a Tab
Type "?" to see Onshape keyboard shortcuts. Click on the arrow to make it a floating window you can keep visible.
'P' will hide/show all planes
Uploading and translating a file creates at least two Tabs: one for the original data file, and one or more for the Onshape Parts and Assemblies that are the results of translating
Onshape Part Studios:
Are designed to let you make many parts in one Part Studio
You need to Sketch before you Extrude
Extrude can make add material, cut material, or make a New Part (or of course Intersect -- powerful but not common -- or is it?)
Extrude can extrude *faces* not just sketches -- very handy
Onshape Assemblies:
Use high-level mates that often allow you to mate two parts using one mate instead of two or three
Use *Mate Connectors* that are a bit like reference coordinate systems
You can create Mate Connectors in advance in the Part Studio, in the Assembly, or on-the-fly while creating Mates
Your thoughts?
I'll start:
General:
Onshape Assemblies:
Your thoughts?
LearnOnshape facebook group
/Scott
Dries
The Properties have also been set for each release including part#, description, release "state", etc. See Properties under the gear/action icon for the version. Note that "State" may only be set on a saved version. The State of a workspace is always "In Progress". All properties (meta-data) are transferred from the workspace to the version on Save.
The process for setting properties/meta-data is:
1) Set all the part/assy properties in the workspace
2) Save a version
3) Edit the properties of the saved version and set the State as necessary.
Eventually we will wrap the properties in a workflow with privileges to control changes. The properties of a version are not immutable.
This document is public as:
https://cad.onshape.com/documents/559b9a459ca348529d9f4761/w/1a1b32a12ea147c99f1a0672/e/afe404dadfb243718c9e2a15
Comments and feedback on versions is greatly appreciated.
Traditional CAD users are coming from the "part is a file that can be placed in an assembly and both can be nested" paradigm.
Is there any resource here that covers this?
In just about every company I've worked for there was a need to document "as-built/shipped" products. Unlike mass produced products that rarely change, there are many companies who build custom machines. Imagine a complex machine built for a customers. Over time, the design will change and evolve. Components once used may no longer be available as time goes on. So it is desirable to identify and "freeze" a design at a given point in time to represent what was shipped to the customer (i.e. for field servicing) - even though now the machine has been since updated and evolved.
Is this the kind of scenario that OS branching can address?
-Jim
There's an interesting parallel that can be drawn from the Apple iCloud offerings. You have four Apple apps; Pages (word processor), Numbers (spreadsheet), Mail and Keynote (presentations). These can read/write MS Office docs too. There are iOS and Mac OS X versions of these apps - as well as a web-based interface. I use these personally in my day-to-day work (while everyone else trundles along with classic PCs and MS Office.
I record test data into Numbers from my iPhone - save it to the web and then process and massage these data from my web browser on my PC. I then show people the graphs/charts in person on my iPad.
I have been surprised at the slow-uptake of the power (and low-cost) of this combo by my peers. What seemed self-evident to me - required a bit of explanation and demoing before the light bulb finally went off.
-Jim
"There is nothing more difficult to take in hand, more perilous to conduct, or more uncertain in its success than to take the lead in the introduction of a new order of things, because the innovator has for enemies all those who have done well under the old condition, and lukewarm defenders in those who may do well under the new.
- Machiavelli, 1513
Amen to that! And loving the Machiavelli quote...
Dries
John
And just confirm, those saved branches will not update unless one takes specific actions to do so?
-Jim
I love the quote, too. I just added it to my list of quotes that is saved on my OneDrive account, hah!
Unless you have lots of sheet metal, in which case it will take a while to finish regenerating.
